15 min
Intermediate
- Use smart values in flows
- Use branch flows to perform multiple actions
Let's explore an example
"parent" is not EMPTY
How was this lesson?
next lesson
Best practices for managing automation flows
- Manage automation flows
- Troubleshoot automation flows
